Noob needs help
Go to solution Solved by acidprototype,
Hi I am new to this forum and I am planning my first build and i would like to water cool the system and the processor i have chosen for this build is an intel pentium g3258, i have been looking around to find a compatible water block but i have had no success and i am writing this to ask if there is one out there that will fit this processor.
The compatibility for cpu water blocks is down to the socket on the motherboard. Intel 1150, 1155, 2011 etc and AMD AM3+, FM1, FM2 etc.
If you looking at closed loop liquid cooler, it will fit almost all modern cpu types (including yours). If you want a custom loop, the cpu block will be compatible with nearly all cpu socket types.
https://linustechtips.com/topic/224764-noob-needs-help/
Water blocks don't fit the processor, they fit the motherboard/socket.  Grab a Kraken x41/Kraken x61.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/224764-noob-needs-help/#findComment-3078956
Not worth water cooling the Intel Pentium :/
CPU: I5 7400 | Motherboard: MSI H110M  | RAM: 16GB G-Skill 2400mhz  | GPU:  NVIDIA  MSI Gaming 4G GTX 970 | Case: Tecware Quad | Cooling: Stock| Storage: Kingston 120gb SSD, 1TB Drive ,  | PSU: Seasonic 620 Watt 80+ Bronze Full Modular | Display: Devant 50 Inch Smart TV   |
https://linustechtips.com/topic/224764-noob-needs-help/#findComment-3079097
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
https://linustechtips.com/topic/224764-noob-needs-help/#findComment-3081927
