Yep.
But the GPU will still be at 99-100% usage, just the game engines themselves won't have as much power to use as newer/faster CPU's, hence overall FPS will be slightly lower compared to better CPU's.
GPU will be working fine, just with lower MIN/AVG/MAX fps across the board.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/224577-will-it-bottle-neck/#findComment-3076319
Everything hits a bottleneck. A bottleneck is basically the limiting factor. It's just recommended to buy components that hit their limits at the same time in your desired task.
If I had to say, I would say your CPU would bottleneck your GPU in certain CPU intensive games. What really are you trying to do with this system?
https://linustechtips.com/topic/224577-will-it-bottle-neck/#findComment-3076333
https://linustechtips.com/topic/224577-will-it-bottle-neck/#findComment-3076357
Hey techtip fans! Im building a new computer. And im not sure if it will bottleneck
Cpu:fx 4300
Gpu:gtx 970
Psu:750w
ram:8gigs
my i5 3350p keeps up with my 780SC, keep that in mind...you might want to upgrade that cpu, if youre dropping the cash on that card dont let it get held back.
https://linustechtips.com/topic/224577-will-it-bottle-neck/#findComment-3076375
It wouldn't run very well, no. I'd suggest at least an overclocked FX 6300, an i5 would be better.
You realize that at its core the 4300 and the 6300 have the same performance right? Only difference is the core clock and the number of modules that are active. The same goes for the 6300 and the 8320/8350.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/224577-will-it-bottle-neck/#findComment-3076380
What's your full budget? Rendering/streaming/etc are all heavily CPU intensive tasks. We can't recommend parts without a budget because the goal is for the parts to all have similar limits for the task. One part in a vacuum is not the answer.
Streaming (Shadowplay) and Rendering (Cuda) can be done with the GPU abilities.
The i3 + 970 would be the way I'd personally go.
Then upgrade to the i5 when possible at a later date.
https://linustechtips.com/topic/224577-will-it-bottle-neck/#findComment-3076485
yeah. that's the point.... 2 more cores on the 6300 makes a difference and as far as I know, there is no way to unlock the disabled cores on the 4300.
It doesn't make a difference if the game the person is playing only uses two cores(or one core module). Having the extra cores is irrelevant if they aren't being used.
https://linustechtips.com/topic/224577-will-it-bottle-neck/#findComment-3076786
that's true, good point. Some of the newer games do seem to benefit from more than 2 cores though, Watch Dogs for example stresses all four cores on my 4670k equally. Nevertheless, given that the single core performance is pretty much identical throughout the entire FX-line, it shouldn't make a big difference if you have an 8350 or 4300, I guess OP would have to go intel then.
https://linustechtips.com/topic/224577-will-it-bottle-neck/#findComment-3076849
https://linustechtips.com/topic/224577-will-it-bottle-neck/#findComment-3079690
