so i just brought the GTX 970 (More specifically Palit NVIDIA GeForce GTX 970 Jetstream) and was wondering what case would this fit in? Kinda new the the PC building area. i'd prefer to spend £35 max on the Case. As long as it can fit, sorry if this has been asked before. i need an answer ;(
Thanks
https://linustechtips.com/topic/224553-need-help-in-finding-a-case/
http://uk.pcpartpicker.com/part/nzxt-case-s210001
You will need to remove a hard drive cage though, otherwise the card is 4mm too long
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
Newb question again is it quite easy to remove the hard drive cage :P? thats a good case, thanks for the find
as long as you have a screwdiver you can or you can do it the fun way with a sledgehammer  :P
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
Thanks for all the help guys, really appreciate it :D NZXT Source 210 it is :D
one thing you should quote the people so they know you have responded to them
One second there, check out the zalman r1. You will not have any clearance issues with it, you also get a free fan controller, basically the same price and it has foam in it to stop sound, sound is bad. Your decision in the end but the z1 is a better case in my opinion.
I won the source 210 and the r1 and i stand by what ive said.
Listen if you care.
