Hi , i was wondering what are these poct code chekpoints? im new to all of this and on my first build i have from 30 - 40 , then 20 - 30 , on my first boot it showed 0F and the second day just random numbers , im using a ECS Z77H2-A2X Black Deluxe motherboard and im hoping you can help me get rid of those , and should i be worried ?
I haven't lost my mind -- it's backed up on a HDD!
https://linustechtips.com/topic/224459-post-code-checkpoints/
Normally when booting the system is putting out these numbers, it's just doing it's checks (POST).
You can always check your motherboard manual if you want to know what they mean.
Check page 93 - 96 in manual.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/224459-post-code-checkpoints/#findComment-3074588
It's just telling you what part of the POST process its at. As long as you don't get errors when booting (or booting at all) then there's no need to worry.
My EVGA 680i SLI does C1 (memory) C3 (cpu states) 76 (additional hardware) and then FF if it's successful.
When it's on it could also be a temp readout for the CPU.
https://linustechtips.com/topic/224459-post-code-checkpoints/#findComment-3074592
they are always switching
https://linustechtips.com/topic/224459-post-code-checkpoints/#findComment-3074593
You'd need to be worried if it gets stuck on a POST code. If they're changing it just means it succesfully initilized the BIOS, various interfaces and so on.
https://linustechtips.com/topic/224459-post-code-checkpoints/#findComment-3074622
The most common number is 30 and according to the manual it is reserved for ASL , and again , what is asl i cant seem to find it ?
https://linustechtips.com/topic/224459-post-code-checkpoints/#findComment-3074645
Unless your computer fails to boot, I wouldn't worry to much. All the codes are really helpful for is troubleshooting if you are having problems. If not, don't worry about it :D
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/224459-post-code-checkpoints/#findComment-3074947
