[problem] Terrible colors
Go to solution Solved by DigitalHermit,
Did it, but the current settings are the best ones.
Have you tried resetting your TV/Monitor's settings? There are also color profiles on most monitors, maybe you can fix it there...
Hey guys,
Since yesterday evening (using the same monitor as before) my colors are all messed up. Currently they look as follows:
http://puu.sh/bSpfP/f36bef4d7f.jpg
And I was wondering how I could change them back; rebooting didn't work and neither did windows color calibration or switching themes.
https://linustechtips.com/topic/224421-problem-terrible-colors/
Yep a screenshot isn't going to work there :P.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/224421-problem-terrible-colors/#findComment-3074111
Oversaturation?
Try looking for the color correction options in the software suite that comes with your graphics card driver...
https://linustechtips.com/topic/224421-problem-terrible-colors/#findComment-3074140
https://linustechtips.com/topic/224421-problem-terrible-colors/#findComment-3074194
