Why would that effect proformance?
Binning means they take the best pieces of silicon and use them for more expensive products. You got piece that isn't as good.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/224400-overclocking-woes/#findComment-3073822
6+2 power phase and silicon lottery, that's the problem plus why did you get that mobo anyway?
If you wanted to overclock your 8350 to 5ghz,(IMO) i would recommend getting a 990fx chipset mobo instead of a 970 chipset mobo if you are gonna overclock your fx 8350 or 8320 to 5ghz and above.
https://linustechtips.com/topic/224400-overclocking-woes/#findComment-3073823
Hey guys, I built a new PC yesterday and I'm trying to get my 8350 to hit 5ghz but it won't go over 4.6 :/ I have the MSI 970 Gaming motherboard and a H100i. Any ideas?
Need to know voltages, temps, etc.
Every chip is going to OC differently, only guaranteed speed is what's rated (4.2 w/turbo for the 8350). May have just gotten an unlucky chip draw.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/224400-overclocking-woes/#findComment-3073830
Most people haven't been getting 4.7Ghz+ 8xxx chips since the 9xxx chips came out because AMD kept them all back to become 9xxx chips. It's unlikely that even if you got a different board that it would make any meaningful difference.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/224400-overclocking-woes/#findComment-3073843
So everyone just come to a conclusion without asking a single question about the OP's settings WOW...
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
https://linustechtips.com/topic/224400-overclocking-woes/#findComment-3073925
