correct me if im wrong but the tdp on haswell is higher than ivybridge and a 780..., you might be getting close to the psu max.
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/22422-potential-haswell-build/#findComment-282478
iirc, the tdp is less because of the new architecture :)
i5 3570k@4Ghz, Sapphire Radeon 6850@870/1290, Gigabyte z77 ud3h, 8GB 1600mhz Corsair Vengeance RAM, Acer 232hl, Asus vs238h, Corsair K60, CoolerMaster Recon
https://linustechtips.com/topic/22422-potential-haswell-build/#findComment-282507
Looks solid. I'd get the non pro samsung 840 to save some money. The difference between the pro and non-pro isonly really important when the ssd is used as a scratch disk.
For a boot drive/applications, the non-pro feels the same. You could bump up to the 250GB version for video game space.
Edit: Also, platinum is overly expensive. A bronze plus will do.
https://linustechtips.com/topic/22422-potential-haswell-build/#findComment-283769
It would be better to post again when you're closer to buying.  If you pick parts now, and you don't buy within 3 days, your build is going to change as more hardware is released this year.
However, here's a sample build I put together.
http://pcpartpicker.com/p/14rEI
https://linustechtips.com/topic/22422-potential-haswell-build/#findComment-313016
