Nice username.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($199.95 @ NCIX)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($94.00 @ Vuugo)
Memory: Kingston 8GB (2 x 4GB) DDR3-1333 Memory  ($79.88 @ Canada Computers)
Storage: Toshiba Product Series:DT01ACA 1TB 3.5" 7200RPM Internal Hard Drive  ($54.79 @ DirectCanada)
Video Card: Zotac GeForce GTX 770 2GB Video Card  ($298.00 @ NCIX)
Case: Cooler Master Elite 120 Advanced (Black) Mini ITX Tower Case  ($28.95 @ Vuugo)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.98 @ NCIX)
Total: $805.55
Generated by PCPartPicker 2014-09-28 18:07 EDT-0400
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
Total: $805.55
ilusm
Motherboard: ASRock Z97M Pro4 Micro ATX LGA1150 Motherboard  ($107.50 @ Vuugo)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($83.36 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($56.98 @ DirectCanada)
Video Card: Asus Radeon R9 280 3GB DirectCU II Video Card  ($209.99 @ Memory Express)
Case: Fractal Design FD-CA-NODE-804-BL MicroATX Desktop Case  ($94.99 @ Canada Computers)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Memory Express)
Total: $792.76
Generated by PCPartPicker 2014-09-28 18:09 EDT-0400
Or
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($154.99 @ Canada Computers)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard  ($62.12 @ DirectCanada)
Video Card: Diamond Radeon R9 280X 3GB Video Card  ($259.99 @ NCIX)
Total: $781.61
Generated by PCPartPicker 2014-09-28 18:11 EDT-0400
Total: $792.76
This is a good build for what your wanting but... If you dont like the case which personally I hate Micro-ATX cases, go for the Deepcool Tesseract. It has a sexy look on the outside and a good amount of room on the inside. There are 3 different types of cases for the Deepcool Tesseract, there is the WH, SW, BF. I am getting the SW which is black matte color and has a window with blue LEDs inside the case. And you will be saving money so you wont be spending $800 all the way so you get the best bang for your buck.
Case: BitFenix Prodigy (White) Mini ITX Tower Case  ($59.99 @ Canada Computers)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($34.99 @ Memory Express)
Total: $739.26
Generated by PCPartPicker 2014-09-28 18:21 EDT-0400
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
I think NCIX has the y510p for around 900 if you'd like to go that route, although i'd personally prefer a portable desktop
Specs: i7 4790k, r9 280 windforce OC, 8gb hyperx fury 1866 RAM, z97 PC Mate, 256gb mx100, black pearl r4, 2tb WD Red (soon)
