24 inch 1080p monitor for gaming?
RevoltTrain
What are some of the best 24 inch gaming monitors for under $200?
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
Under $175, my Acer H236HL is 23", has beautiful bezels, cheap ($150), IPS. I would recommend it. It's not advertised as a "gaming" monitor, but I play games on it and it works flawlessly. I'm sure there's other monitors out there aswell.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
if you want the absolute best it is above your budget, believe it is $225-$250 asus vg24qe 144hz,1ms, 24 in 1080p
if you want the absolute best it is above your budget, believe it is $225-$250 asus vg24qe 144hz, g sync, 1ms, 24 in 1080p
You won't get the gsync version for $225-250, that would just get you the 144hz version
$265 http://www.amazon.com/VG248QE-24-inch-LED-lit-Monitor-response/dp/B00B2HH7G0/ref=sr_1_1?s=electronics&ie=UTF8&qid=1411938280&sr=1-1&keywords=asus+vg24qe
product model VG248QE includes g sync.. dont know what you're talkin about
edit: my bad it doesnt
There's the asus vx239h (23" monitor w/o speakers) or the mx version if you want that. Not a gaming monitor, but AH-IPS and good enough response time unless you're some hardcore gamer. Anti-glare screen aswell which I would kill for. My glossy dell is almost ike a mirror lol.
I know you asked for 24", but thought these are nice monitors worth mentioning.
That monitor does not have G-sync built in, it is G-sync capable. There was a G-sync module sold for about 200 bucks that can be added to this monitor.
CPU: Intel I7-4790k | MOBO: Asus Sabertooth Z97 Mark 1 | Ram: Corsair Vengance 32GB 1600hz | GPU: EVGA GTX980 Reference
PSU: Corsair EVGA G2 850W  | SSD: Intel 730 Series 480GB, Kingston SSDNow V300 120GB | HDD: WD Black 1TB
 CPU Cooler: Corsair H105 | Case: Corsair 760T (White) | Peripherals: (2)Asus VS247H-P, Corsair M65, Corsair K70 RGB w/ Brown Switches
Yeah it seems you guys are right, my bad
Asus VN248H-P
Bert & Ernie before squirting spermie.
