I purchased a Crossblade Ranger about 2 weeks ago and everything is great besides 1 little thing...  It doesn't like the internet.  Here is what I know:
I use a ASUS PCE-AC68 adapter to connect to the internet.
If the onboard Intel NIC is "Enabled" I can connect to the network, but I can not access anything on the network.  (over the wireless network obviously)
When the Intel NIC is "Disabled" I can connect to the network, and access things on the network with tons of hassle.
When I open up a webpage it will act as if it is loading, but never does.  If I "Stop" the command in the web browser the address bar will go from whatever I had put in it to completely empty.  If I retype what website I want, then it almost always works.
My NAS (WD My Book World) will only connect for about 5 minutes then completely disconnects from the network, but the router still sees it (from within the web admin tool).
This all happened with the change of motherboard-cpu-ram.  As before I had a Sabertooh 990FX and everything work wonderfully.
I am concerned that something with Windows did not install correctly (maybe a .net framework)
All games connect to their respective networks without any issues, it seems anything using a Windows Explorer backbone is all that is effective.  I had installed all of the newest drivers (as of 9/12/2014) but I have noticed 2 updates on ASUS's website before doing this thread that I am going to try as soon as I am done.
Any advice from anyone, thank you very much.
--- Edit:
I am 99% sure this is being caused by AI Suite III's built in traffic monitor.  I been poking around at it and it seems that it was by default turned on, as I had never changed it.  I think that maybe some of these packets were lost as "web browsing" is put on a lower priority than other things.  For example my Battle.net launcher is considered a "game" in the profiles and automatically launches upon PC start up, so there for no matter what "web browsing" is put at a lower priority.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/223773-internet-problems/
When troubleshooting something, it's always best to simplify things.
So for example, in your case:
1- Use Windows built-in Wireless manager. (they alternative ones usually sucks bug time)
2- Remove any software that manages traffic. (These software usually does a horrible job)
3- Remove any internet security software.
4- Remove any firewall software beside the Windows built-in one.
You also want to try direct wired connection from the modem to the Ethernet, to rule out a system problem at a software level and router.
https://linustechtips.com/topic/223773-internet-problems/#findComment-3065631
If you checked out the stuff I posted, the PCE-AC68 adapter doesn't have a management software.  It has its utility, but it doesn't use it to connect to the network, only to enable things like beam forming.
point #2 Ill get to in a second
if you have internet security software that interferes with your traffic, what in the hell are you doing with your life?  Windows' built in Firewall does a good enough job when paired with IE and MSE/Windows Defender that no one should ever have to use anything else.
I don't know why people suggest using a wire like its okay to run a cable through your house?  I'm sorry but it is wireless ONLY, no exceptions.
Okay so what I have noticed:
As I edited to previously state I believe it has to do with ASUS AI Suite's traffic monitor, and as of now it seems to be wonderful.  I updated all the programs (because the 2 updates were to do with the AI Suite III and Game First III, not drivers themselves).  And it got better, at least all the websites I tried didn't require reloading.  So I opened Game First III and just turned it off and almost instantly everything went back to the way it always had been.
But I do want to let people know that Game First II actually did what it was suppose to do, and quite well.  I had noticed WoW didn't DC half as often as before (like I stated during the first post all my games were awesome), it was only my "normal" network traffic that suffered.  So if your someone that does nothing but game, and I know there is tons of you out there, Game First is a essential in my opinion.  Stay tuned for more updates.
https://linustechtips.com/topic/223773-internet-problems/#findComment-3066473
PS I know I seemed harsh, I know you meant good.  I just hate people suggesting a cable when what I want is wireless (and even vice-versa)
https://linustechtips.com/topic/223773-internet-problems/#findComment-3066480
  • 4 weeks later...
Turned out to be ASUS Game First Software.  So I turned it off, and all my internet problems have went away.
https://linustechtips.com/topic/223773-internet-problems/#findComment-3279297
