Help ! Air cooler Mod
Go to solution Solved by Enderman,
You can paint the fan frame on the outside with no consequences. If you paint the blades, you need to use a very thin paint coat or it can start causing more noise.
Yes you can paint the top of the heasink black as long as you use a paint that can stay on metal at high temperatures, at least 90C+ degrees
I will be buying a Noctua NH-D15 but the noctua fans for me is ugly . how can i paint them to color black and red ? if i paint it will lessen its performance ? and the silver heatsink can i paint the top to black ? i attach some pics . i want to paint the box red ones to black only the top not all parts of heatsinks can it be ? sorry for bad english
post-109867-0-03084200-1411882366_thumb.
https://linustechtips.com/topic/223738-help-air-cooler-mod/
https://linustechtips.com/topic/223738-help-air-cooler-mod/#findComment-3064855
Buy different colored fans?
Also, pretty sure painting the top won't make a difference to performance.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/223738-help-air-cooler-mod/#findComment-3064857
like Enderman mentioned, just make sure the paint you are getting can withstand temps of 90-100c
also avoid a thick coat.
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/223738-help-air-cooler-mod/#findComment-3065048
here's my NH-D14 painted up:
took a bit to mask off to make it right, but in fairness i'd been better off a satin black.
yours in red would be ok, but prolly too "bright"
Hey ! Airdeano , can you please post some more pictures of your Rig i just want to see all the angles when NH-D14 is painted in white and installed on a System Please ?
https://linustechtips.com/topic/223738-help-air-cooler-mod/#findComment-3066403
