Noise isolation headset?
Solved by BoltActionWaffle,
Just going to be used for light gaming, skype and music. So sound quality doesnt have to be anything crazy. Would need to be pretty comfortable as I work on the computer all day with my headphones on usually. Decent mic quality for skype, nothing serious.
Like I said, I might have not used the best headphones for your needs, but check out the HyperX Clouds, you might like them. Maybe someone else will be able to recommend something with better isolation or something, though the Clouds isolate quite well already.
