Hey there, I am currently purchasing parts for my first PC the parts list is as follows;
-Silverstone KL04
-Gigabyte GTX 750ti Black Edition (2GB)
-Intel 520 Series 240GB SSD
-Intel Core i5 4660
-EVGA SuperNova 750w
-MSI H97M-G43 Motherboard
-Kingston HyperX Fury 8GB (2x4GB) Black
Total About $1,100 (AUS)
Just wanted to know some thoughts.
P.S, I have only brought the case, GPU, SSD and RAM.
https://linustechtips.com/topic/223001-first-pc-build/
-Silverstone KL04
-Intel Core i5 4660
If anything you'll be bottlenecked by the GPU. You'll still be able to run games fine on good settings.
Also I would look into getting a HDD just for general storage and save the SSD for your OS and anything else you use a lot.
I'm assuming this is for gaming.
https://linustechtips.com/topic/223001-first-pc-build/#findComment-3055554
I would recommend something like this if you wanted a system that would go along with the parts you have with no problems
CPU: Intel Core i3-4360 3.7GHz Dual-Core Processor  ($169.00 @ CPL Online)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($39.00 @ Mwave Australia)
Motherboard: Asus H97-PLUS ATX LGA1150 Motherboard  ($127.00 @ Centre Com)
Total: $423.00
Generated by PCPartPicker 2014-09-27 11:59 EST+1000
https://linustechtips.com/topic/223001-first-pc-build/#findComment-3055585
I am looking at spare computers from family and friends for a HDD that i will wipe and then use for my PC.
I will be replacing my GPU first, its just I will be short on money and needed a cheap GPU and there was a sale so.
https://linustechtips.com/topic/223001-first-pc-build/#findComment-3055669
Total: $423.00
Is the CPU cheap because that will be all I need or.
I have the 750W power supply just in case, like if i upgrade it or anything.
I wasnt going to have a CPU cooler but I like the recomendations thanks a bunch.
https://linustechtips.com/topic/223001-first-pc-build/#findComment-3055676
If your going to be doing multitasking an i5 will do better. The stock fan will be fine with either of them unless you OC, then i would probably get a aftermarket cooler.
Your rig won't use very much power at all either so even if you do upgrade the GPU you would still have headroom.
If you're going to just game and browse the web then an i3 would save you some money.
https://linustechtips.com/topic/223001-first-pc-build/#findComment-3055805
Would you be able to recommend a good cooler then?
https://linustechtips.com/topic/223001-first-pc-build/#findComment-3055854
@OP ( TheFlow )
Here's a Suggestion, there are sub forums further down the page.
 New Builds and Planning is a good place to look...
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/223001-first-pc-build/#findComment-3055884
