Modular PSU help
Go to solution Solved by tommy-b-10,
Thanks for your help guys!
Not sure who to mark correct, so ill do this post :P
Cheers!
Thats a video on the 1000w version, so it looks good. I can get it for $130 including shipping so thats good :D
Intel i7 3770k @ 4.5GHz, Gigabyte GA-Z77X-UD5H, Gigabyte GTX 770 4GB Windforce, 16GB G.Skill - NT 1600MHz, 250GB Samsung Evo SSD, 2x 1TB Seagate HDD, Corsair H100i CPU cooler w/Noctua Fans, 4x SP120, Fractal Design Define R4, LG W224T, Func MS-3, Apple Numeric Keyboard
-   BBR4 Hackintosh   - Server Rig
https://linustechtips.com/topic/22271-modular-psu-help/page/2/#findComment-280378
Cheers!
https://linustechtips.com/topic/22271-modular-psu-help/page/2/#findComment-280395
Cheers!
This is the best PSU reviewer website review both
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=316
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=169
You can't walk out of your own story - Rango
https://linustechtips.com/topic/22271-modular-psu-help/page/2/#findComment-280419
Just another quick question, how hard would it be to sleeve a non-modular psu? Would it involve taking it apart to get the sleeves to look neat?
https://linustechtips.com/topic/22271-modular-psu-help/page/2/#findComment-280440
Silverstone Strider Plus 600w is $109 at PCCG - fully modular, well built and trusted. :)
Does that website look as shit for you as it does for me? The styling is way off for me
https://linustechtips.com/topic/22271-modular-psu-help/page/2/#findComment-280448
Yes you will have to take the PSU apart to sleeve it :)
https://linustechtips.com/topic/22271-modular-psu-help/page/2/#findComment-280449
Ahk probably too much effort than what its worth, plus so many cables going everywhere as well.
https://linustechtips.com/topic/22271-modular-psu-help/page/2/#findComment-280457
Actually Silverstone PSU, some of them are made by Enhance... the build quality is great! The Seasonic is overrated, make a little research, you'll find that the Seasonic X-Platform has alot of coil whine issue and ALOT of these PSU has been RMA'd!
Thanks!
https://linustechtips.com/topic/22271-modular-psu-help/page/2/#findComment-280816
Xigmatek Make a good 800w and 700w power supply on their Centauro Series. They are fully modular apart from the 24 pin and 8 pin. They are good and you can just use extensions for the cables and manage the unsleeved cables behind the motherboard tray.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/22271-modular-psu-help/page/2/#findComment-280822
