Modular PSU help
Go to solution Solved by tommy-b-10,
Thanks for your help guys!
Not sure who to mark correct, so ill do this post :P
Cheers!
Hi guys, so I'm looking for a fully modular power supply that can power a 3770k and GTX 660.
I was looking at corsair 650w TX series, but they are only partially modular. Is there anything that is fully modular but around the same $100-120 price range?
Cheers!
Intel i7 3770k @ 4.5GHz, Gigabyte GA-Z77X-UD5H, Gigabyte GTX 770 4GB Windforce, 16GB G.Skill - NT 1600MHz, 250GB Samsung Evo SSD, 2x 1TB Seagate HDD, Corsair H100i CPU cooler w/Noctua Fans, 4x SP120, Fractal Design Define R4, LG W224T, Func MS-3, Apple Numeric Keyboard
-   BBR4 Hackintosh   - Server Rig
https://linustechtips.com/topic/22271-modular-psu-help/
AX series from corsair
Or Antec PSUs are good
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280193
Cheers, but I was more after something cheaper... if there is nothing that okay, but it will make my project a hell of alot easier if there is one.
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280216
You shouldn't cheap out on your PSU. It is important that you have a high quality reliable PSU.
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280237
Im not looking for a cheap brand or anything, just wondering if there is any other solutions out there, the reason I want it modular is for sleeving and cable management. If not then I will probably just take apart a non or semi modular one and sleeve that, just more work :P
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280251
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280252
Iv never heard of SeaSonic, are they a good quality brand?
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280257
Just looked up the seasonic x650 review by linus, looks good guys, thanks a heap!!
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280270
Thanks for literally copying my link joel.....
Sorry, i didnt see your post while i was looking
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280294
I figured you didn't, I was just fucking with you :P
Kinda figured but i figured i would apologize Just incase
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280307
If you are thinking about the seasonic you might want to jump on it because it is on sale for 33% off right now which is why it is so cheap!
Sorry guys! I just looked up the seasonic, and as I live in Australia, Its actually more around $250 here!
So I'm back on the search :P
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280314
Check out the other link I had in my post. It is a silverstone which is also a well known brand that I have heard good things about. Fuck it I'll link it again lol
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256087
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280324
IMO Silverstone isnt that good, PSUs need to be AMAZING for them to get anywhere near my PC
they arent bad but ya
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280337
Cheers, I forgot about that one! Yeah I found that one on http://www.techbuy.com.au for $130 including shipping so thats pretty decent.
Any other suggestions? :)
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280341
Thanks, thats a better version of what I have been looking at, a little but more expensive.
What about this one? Its halfway :P
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280356
It's good but not better then the seasonic.
haha yeah I get that, but for me $250 is just not justifiable when I can just get a non-modular and mod it.
https://linustechtips.com/topic/22271-modular-psu-help/#findComment-280365
