Hello,
I am looking for a fanless cpu cooler for the lga 1150 socket that will fit on the msi b85-g41 in a fractal design define r4 with low profil ram.  Obviously, its not for performance, its for being quiet.  Preferably sub 40$.  I have an i5 4570 so no overclocking anyway.
Thanks
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/222453-cpu-cooler/
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/222453-cpu-cooler/#findComment-3048837
not sure if it will fit in define R4 (should) but.. http://www.newegg.com/Product/Product.aspx?Item=13C-0007-00002&cm_re=fanless_cpu_cooler-_-13C-0007-00002-_-Product just be careful as they do need at least a little air flow to pull the heat out.. I haven't run fanless in a LONG time..
https://linustechtips.com/topic/222453-cpu-cooler/#findComment-3049005
212 EVO.
Hyper 212 Evo, or just stick to your stock cooler if you don't want to spend money on one or a fanless cpu cooler if you want no noise at all.
I don't recommend fanless coolers. Just get a 212 evo with a Noctua or be quiet fan.
Can I use the hyper 212 evo and just remove the fan?  It seems like a good cooler design and i have 2 140mm intake fans and a 120mm out take fan.
https://linustechtips.com/topic/222453-cpu-cooler/#findComment-3049014
why not just set the bios to auto level the CPU fan so it turns down the speed when its not being pushed? most modern motherboards support this.
https://linustechtips.com/topic/222453-cpu-cooler/#findComment-3049066
Hmmm Fanless coolers need very good airflow from your fans. 2x140mm and only one small 120mm out take fan is not what I would consider especially good airflow.
Turn down the RPM of the cpu.....
The Mistress: Case: Corsair 760t   CPU:  Intel Core i7-4790K 4GHz(stock speed at the moment) - GPU: MSI 970 - MOBO: MSI Z97 Gaming 5 - RAM: Crucial Ballistic Sport 1600MHZ CL9 - PSU: Corsair AX760  - STORAGE: 128Gb Samsung EVO SSD/ 1TB WD Blue/Several older WD blacks.
https://linustechtips.com/topic/222453-cpu-cooler/#findComment-3049090
the 80mm stock fan is too loud for me no matter what
Ok, then ill probably just go witha  hyper 212 evo, that should be quiet enough.
https://linustechtips.com/topic/222453-cpu-cooler/#findComment-3049093
