New Water Cooling Loop
Go to solution Solved by Shaqo_Wyn,
Well it all works together. I assume you're on a budget? The 750D being a pretty large case there are different components you can utilize.
Rad: low fpi - for example a 360 Alphacool XT45 in the top
Pump: DDC or D5
Res: EK 100 or 140 X-RES
Pump: DDC or D5
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/222255-new-water-cooling-loop/#findComment-3046856
You could also buy an EK kit like the one linked below, pretty much the same stuff except little bit cheaper. Other than that, looks ok.
http://www.frozencpu.com/products/18964/ex-wat-249/EK_L240_Complete_Dual_120mm_Liquid_Cooling_Kit_EK-KIT_L240.html?tl=g57c607s1948
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/222255-new-water-cooling-loop/#findComment-3047096
