Dual Monitor Setup
LeonE
Hello techers,
I want to run a dual monitor setup but i need some help.
Are there things i need to be vary of when buying my second monitor? I'm currently running http://www.newegg.com/Product/Product.aspx?Item=N82E16824236307 and thinking of buying this    http://us.acer.com/ac/en/US/content/model/UM.FG6AA.B01
Are these 2 compatible and last but not least how do i get started once i get my 2nd monitor, what cables ect are required?
- Leon
There should not be any problems other than they might be different heights. You would need another video cable.
Hey. What monitor you get it no problem, the same size can be handy. But you're not going to want dualmonitor setup if you want to game on both, the bezel would simply be in the middle in all your games.
I love StarCraft
Intel i5 4670 @3.4Ghz - Gigabyte G1 Gaming Gtx 970 @ 1542Mhz - 120GB Kingston SSD - 1TB Seagate HDD - Gigabyte B85-H3D - 8 GB 1333Mhz Kingston RAM - Azza Toledo 301 - SteelSeries Sensei/Logitech G400s - Razer Blackwidow 2013 Ultimate - Sennheiser HD 598 - Zalman Zm-mic 1
 http://www.last.fm/user/thalandros
http://www.mysteamgauge.com/account?username=76561198044810844
Haha, I misread the end of your post and thought you were trying to tell the OP that he/she needed another Video Card, and I'm thinking "what the heck? No he/she doesn't.". It pays to read things twice or even thrice if needed. :D
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
Ok so all i need is a display connector? The problem is this computer doesnt support DisplayPort does that mean i wont be able to fully utilize the 144hz?
