Asus VE278Q 27-Inch Monitor
TheKDub
Hello, I have been searching for a monitor to replace my samsung syncmaster 225bw (I'll use the samsung as a 2nd monitor, It just is a bit small for my tastes), I decided that the ASUS VE278Q looked like a good choice.
does anyone here own this monitor? if so, would you suggest that I get it? or should I keep searching?
http://www.amazon.com/Asus-VE278Q-27-Inch-Integrated-Speakers/dp/B0043T34RK/ref=sr_1_8?s=pc&ie=UTF8&qid=1411430735&sr=1-8&keywords=Monitor
If you have a better monitor to suggest that is under $250 USD, is 27", has small bezels, vesa mount support, HDMI & DVI (DP would be nice) inputs, 1080p or 1440p, good color reproduction, and is black then let me know!
