What do you do on your PC? For most uses, x99 is overkill. Also, x99 isn't a replacement for z97, its a completely different product series.
Intel Core i7 4770k - 2x Geforce GTX 780 - MSI Z87 MPower Max - Corsair H60 - 8GB Avexir Core Series MPower Yellow + 4gb no-brand DDR3 - Corsair Obsidian 750d - AData XPG SX900 256gb SSD - Seagate Barracuda 3TB (7200 RPM) - Hitachi 250GB 2.5in HDD (3200 RPM) - WD HDD 160GB extracted from iMac via black magic (no specified RPM) - ASUS VG248QE 144HZ 3d Vision Monitor - Logitech G602 - Ducky Shine 3 TKL - AKG 172 HD Headphones - Xperia z2 - Sony Noise canceling earphones -  Nikon D5200 With Bundled Lenses - Windows 7 Home Premium - Blue Snowball iCE - Acer Aspire X with a broken case, AMD A6, and Raijintek Aidos CPU heatsink
https://linustechtips.com/topic/220665-stuck/#findComment-3024995
and what do you mean by work load?
They mean what you use your pc for. It isn't worth upgrading it seems in your case. And no, DDR3 still has a long life ahead of it.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/220665-stuck/#findComment-3025025
DDR4 hasn't yet rendered DDR3 irrelevant.. it isn;t even close to doing that yet, x99 mobos are overkill for most things and are for people who need the insane performance, although if you are comming from a Z97 with an i7 on it you won't see much of a difference unless you are doing crazy big video editing projects or something similar
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/220665-stuck/#findComment-3025094
