Okay, so, I am currently in the midst of a problem, as with most people on here likely are.. I recently began a mission to remove the OC panel from my front panel, with the goal of extending it... I took the necessary photograph in glorious 36MP with my D800, and ensured that I could tell what went where. Sadly, one of my roommates neglected to follow my "remove ALL cards before use!!!" rule, and in doing so, ended up deleting my photographs... To that end, I really need someone to either photograph (over 24MP probably), or write out (with a color-coded key), a list of the wires and where they go. This way I can replace the short cables with the SINGLE long, shielded cable I purchased (18 conductor+ground) If anybody is able to help me with this, I simply have not found the pinout for both ends, and a fellow over on OCN.net has not followed through with his promise to send it on over (Although he did immediately send pictures, we agreed they were not sufficient enough to see some of the wires' locations).
Please, oh please, someone with one of these cables send me the pinout of both ends of each connector...
Thanks all!!!
~J
https://linustechtips.com/topic/220575-oc-panel-cable-extension/
What do you mean by 'super long' ?
The current output by your motherboard to the ROG_EXT header is not a lot. Anything over 10-20ft will not let the signal reach your OC panel.
https://linustechtips.com/topic/220575-oc-panel-cable-extension/#findComment-3023705
You could try googling it?
That was actually the first thing I attempted, sadly there were no high quality images that I felt comfortable with...
Super long is about ~6ft. I believe that with the quality of cable I am using, the gauge, shielding and TPI, it will prove satisfactory.
https://linustechtips.com/topic/220575-oc-panel-cable-extension/#findComment-3024388
Oh 6ft should be fine.
Have you seen these?
front-base-cable-q-connector-motherboard
https://linustechtips.com/topic/220575-oc-panel-cable-extension/#findComment-3024409
In all honesty, I just need the pinout, if it does not work at the length I intend (~6ft), then I will just go down until it does, and drop about 10% off that for good measure. Have done low-voltage work for about five years I am confident in my assessment that this will work, and although I have gone a little overboard with the cable I am using, I am just lacking the full pinout of the unit... So if someone either knows where I can find it, or if someone is willing to take the requisite five minutes to write it down in their own way (I used W-White, B-Blue, K-Black, X-Empty, O-Orange, etc. etc.), any help here would be greatly appreciated. Unfortunately, with cancer and kidney failure, this could not have come at a worse time for me, I finally have nearly complete my 'dream rig', well, as close as I will ever get anyway... lol This is pretty much the last thing to have it mostly finished and satisfactory!
Thanks everyone!!! Take care.
~J
https://linustechtips.com/topic/220575-oc-panel-cable-extension/#findComment-3024452
