Hey guys I'm collecting some build ideas, maybe you can help me out.
I want it to be able to play current gen games and games like WoW at medium-high settings, with the highest power efficiency possible.
Any ideas?
Edit: I don't really care about the price at the moment, just collecting some ideas.
Edit2: Running at 1080p btw!
Thanks in advance!
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
https://linustechtips.com/topic/220465-maximum-power-efficiency-gaming-rig/
intel CPU and a 750ti
First of all, do you have a budget?  If your main focus is on power efficiency, it will have an intel CPU, Nvidia GPU with a high efficiency PSU.
My best guess would be an i3 with a 750ti and an 80+ platinum PSU.
i5 4670k (can OC to 4.4Ghz) - Hyper 212 evo w/ AC MX2 - XFX Radeon R9 280X8GB ADATA XPG V2 DDR3-1600 - MSI Z87 G41 - Corsair CX600M 600W PSU - 1TB HDD - 120GB SSD
Any ideas?
Thanks in advance!
Hi! Well first off, if you're looking for high efficiency, the first step is a good PSU. I would recommend an 80+ Gold (or higher) if you can fit it into your budget. Though 80+ Silver is also good.
For the GPU I recommend something like an R9 270x or a GTX 760. Either one of these will run fairly easy on the power consumption (As long as you aren't overclocking either), but both will give you pretty solid performance, easily matching Medium to High settings at 1080p.
For the CPU, I think a Haswell based CPU is probably best. Getting a non-K Haswell i5 would be a good idea. OR You could spend the extra money for the i5 K edition and undervolt it.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
Yeah forgot to mention that.
No money limit right now, just collecting ideas.
Indeed these are both good recommendations, but I'm a little concerned about their performance for his stated goal (medium-high settings). Assuming he is running a 1080p monitor, an i3 with a 750 Ti might be just a little too under powered.
Here is a build I put together solely based on achieving very low power consumption and good efficiency:
Motherboard: Gigabyte GA-B85M-D3H Micro ATX LGA1150 Motherboard  ($74.23 @ OutletPC)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory  ($69.99 @ Newegg)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  ($139.99 @ Amazon)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($44.99 @ Mwave)
Total: $633.66
Generated by PCPartPicker 2014-09-22 18:40 EDT-0400
The estimated power consumption is 184 WATTS
I do suppose that it is not particularly balanced, so tell me if you would like the budget higher, or performance higher.
For a great, low power, low heat system, use an i5 4690 and a GTX 970. If you can to wait, a GTX 960 would most likely be perfect. A system with these, since they're the main power users, should run under 400 watts easy provided that you don't go overboard. The system, other than power efficient, would also be rather future proof.
CPU: i7 4790k @ 4.6 GHz Motherboard: MSI SLI Plus Krait Edition RAM: 16 GB (2x8) 1866 MHz Kingston Black Fury Series GPU: Gigabyte GTX 970 G1 Gaming Case: NZXT S340 (Black) Storage: Intel 730 Series SSD (240 GB), Seagate Barracuda (1 TB) Display: LG 24MP55 Cooling: Cooler Master Hyper 212 Plus Keyboard: Corsair K95 RGB for gaming (1st Player Fire Dancing for typing) Mouse: Logitech G502 Sound: Corsair Gaming 2100 Vengence 7.1 Headset Operating System: Windows 10
Total: $633.66
Excellent build. Yeah, not exactly balanced, but the OP didn't give us much to go on. Swapping out the HDD for an SSD would be a great addition if the budget was higher. Additionally, I'm not quite sure it would reach the OP's (very vague) requirement of "current gen games on medium-high settings". There was no mention of target FPS or resolution.
