This is my first build. I'm looking to play games at medium-high settings at 1080p 50+ fps. It's also going to be used for light video editing, but considering my ASUS Transformer Book T100TA can do what I need, I doubt that will be an issue. Also, I am in the UK, so technology is much more expensive here than in some other countries.
PCPartPicker part list: http://uk.pcpartpicker.com/p/HKcLpg
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£166.74 @ Aria PC)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  (£50.99 @ Amazon UK)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  (£86.36 @ Scan.co.uk)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  (£60.34 @ Ebuyer)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive  (£52.99 @ Amazon UK)
Video Card: Asus GeForce GTX 770 2GB DirectCU II  Video Card  (£217.49 @ Scan.co.uk)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£58.78 @ Amazon UK)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  (£10.98 @ CCL Computers)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  (£9.58 @ CCL Computers)
Case Fan: LEPA LP70D12R 120mm  Fan  (£3.21 @ Amazon UK)
Case Fan: Corsair Air Series AF120 Red 52.2 CFM 120mm  Fan  (£8.46 @ CCL Computers)
Mouse: Mad Catz R.A.T. 7 Wired Laser Mouse  (£63.98 @ Novatech)
Headphones: Corsair Raptor HS40 7.1 Channel Headset  (£42.20 @ Amazon UK)
Other: Windows 8.1 (£83.99)
Other: AOC E2461FWH (£112.36)
Other: Roccat Isku FX (£69.84)
Total: £1098.29
Generated by PCPartPicker 2014-09-22 21:54 BST+0100
https://linustechtips.com/topic/220412-first-build-and-need-advice/
Please read:
http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
I would advise a different CPU coolerand maybe go for a GTX 970
Also, WD blacks don't have any appreciable gain over regularhard drives
And, your build NEEDS an SSD
Furthermore, what is the case?
Budget?
So many things...
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
I wouldn't buy a 750w PSU that's 80+bronze, get +gold minimum (also go with Seasonic, they have the best ratings and a lot of power supplies out there are seasonics in a different case with a different logo). I'd also get a 970 instead of a 770 gpu if you can. also get an SSD. SOOOOOOOOO much better than plain old HDD
Dubs are better than subs
What case?
The psu is larger than needed. A good 650W until would be better.
Have you considered including an ssd?
I wouldn't bother with additional fans initially. They can always be added later.
Hi Zlambe!
It's a good build you have here.
I'm happy to see you've chosen the WD Black hard drive for your storage device! It's a maximum performance hard drive designed for gaming and more demanding applications, so it's basically perfect for this use.
Also, I'd recommend you do upgrade your GPU, you've already had a suggestion about the GTX 970. The PSU is good, it's always better to have a bit more than needed, but still, @brob has right, may be a 650W would be better; it's more but not too much.
Cheers! :)
CK_WD
If you think I helped, like!  :P
www.wdc.com
