https://linustechtips.com/topic/220391-motherboard-help/#findComment-3021129
The Hero and Ranger line from Asus is a great start. ROG boards look great and can hold graphics cards easily in SLI.
Upcoming build: 4790k OC @ 4.6Ghz, Dual MSI 980 Twin Frozr V, 16 GB Vengeance Pro 2133Mhz RAM, 760T Corsair Case w/ Razer Blackwidow Chroma
https://linustechtips.com/topic/220391-motherboard-help/#findComment-3021131
thankyou guys i am probably gonna go for the Mod 1150 ASUS Z97 MAXIMUS VII RANGER Motherboard becuase it has everything i wanted on it and also it looks badass
James
Edit:  Yeah Tom's right, you need to get an earlier board with a socket 1155 board.
Edited by OllieBarrie
https://linustechtips.com/topic/220391-motherboard-help/#findComment-3021357
James
Dude, it's not compatible with your processor
You have an i7-3770k right? Then you need a socket 1155 board. The one you selected was socket 1150.
Compatible with Windows 95
https://linustechtips.com/topic/220391-motherboard-help/#findComment-3021405
