Difference between VX239H and MX239H? ($175 IPS Displays?)
Guilty Baby
What's the difference between the two? Aren't they essentially the same monitor? By the way, do you guys have any suggestions for some around $175 IPS displays with good colors and okay latency?
Please quote if you want a person to reply, they won't get a notification otherwise.
PC Specs
(CPU: Intel 4790k) (GPU: Gigabyte GTX 970 WF3OC) (Mobo: Asus MAXIMUS VII RANGER) (RAM: Red Corsair Vengeance Pro 2*8GB 1600MHz) (HDD: WD Green 2TB) (SSD: Samsung 840 Evo 120GB) (CPU Cooler: Cooler Master Hyper 212X) (PSU: Corsair RM750) (Case & Fans: Corsair Obsidian 450D) (Monitor: Asus VX239H)
http://computer-monitors.findthebest.com/compare/922-973/Asus-MX239H-vs-ASUS-VX239H
I cant say whats better, but it depends on your use case, personally if you wanna save some money get the VX239H, its practically the same apart from MHL support on the VX-239H but no DVI support unlike the MX-239H, and Black on VX-239H or White on MX-239H
Laptop
MSI GS65 Stealth 8SF
Intel Core i7 8750H, Kingston Hyper X Impact 32GB (2x16GB) SODIMM DDR4 2666Mhz RAM (Ugraded from 1x16GB SODIMM DDR4 2666Mhz), Western Digital PC SN 720 512GB NVME SSD & Adata XPG SX8200 1TB NVME SSD, Nvidia RTX2070 Max Q, 15.6" 1920x1080 144Hz
Screen | Keyboard | Mouse
Dell U2718Q 3840 x 2160 60Hz, Sony KD-438300X 3840x2160 TV | HP EliteDisplay E273q 2560x1440 60Hz
Corsair K70 Rapidfire Cherry MX Speed RGB LED | Corsair K70 Vengeance Cherry MX Brown Red LED
Logitech MX Master 2S | Roccat Kone XTD
Phones
Daily Use: Sony Xperia 1 II | Back Up: Sony Xperia Z5 Premium
Audio
IEM: Sony XBA-Z5, XBA-A3, WF-1000XM3
Headphones: Audio Technica ATH-M50x-BT & ATH-SR50-BT, Sennheiser x Massdrop HD6XX (with Antlion Mod Mic), Sony WH-1000XM4
Consoles
Nintendo DSI, 3DS, Switch, Sony PlayStation 4 Slim
Networking
Asus RT-AX86U | RT-AX82U | RT-AX55 (Asus AI Mesh)
What's the difference between the two? Aren't they essentially the same monitor? By the way, do you guys have any suggestions for some around $150 IPS displays with good colors and okay latency?
One big difference that is evident, if you look at the specifications, is the fact that ASUS has removed their Trace Free Technology from the VX239H completely, which means you can't adjust the pixel overdrive of the display. This means that videos may play back with a stutter and not smooth, like they would normally, and games have the potential to playback with stutter no matter how powerful your PC is if the pixel overdrive is not implemented well.
Also, it appears that the VX239H doesn't have the commonly used DVI port. So you can easily see where ASUS has cut corners to make the VX239H cheaper.
So with that all said, you can probably guess which one I'm going to recommend, yes, I would highly recommend that you go with the ASUS MX239H. :)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
