Recommendations for mATX case?
By
NotSoEpicMods
in Power Supplies
in Power Supplies
Solved by WoodenMarker,
The Node 804, Define Mini, and Arc Mini R2 are good.
The 350D is far from compact and is similar in size to a mid tower. The Node 304 is an mitx case and not matx.The Corsair 350D, Corsair Air 240, Fractal Design Node 304 and Fractal Design Define Mini can all do it.
Neither of those are matx the 230T is a mid tower and the 380T is a mitx case.Corsair 380t? or 230t.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory5 -
derekchan ·
Posted in New Builds and Planning6 -
5
4
6
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting8
play_circle_filled
Latest From ShortCircuit:
