Hello everyone!
I didn't really know where to put this thread so i just started it in off topic  :P
I've been playing my trusty squier p-bass for a year and half now, it's in a red sparkly finish with a white pick guard. As much as i fell in love at first sight when i bought it, i think it's time for a major change: new pikcups, new bridge, new nut, and maybe even a new color.
As far as other component go, i decided to put on a badass bridge to replace the stock one, and a bone nut that i wil cut myself (the one that is on now is cut too deeply and the E string is too low, i didn't do the job myself) and some passive pikcups (probably SD).
But my main question is another one: will i be able, without spending a fortune on spray cans and whatnot, to replicate the same "translucent" paint (like see throught blond)?
I will sand off the entire old paint to the wood, then primer it and start with the color. I don't really now how can i achieve the wood grain to be seen. Probably less paint in the middle and and more on the sides, like a 1 tone sun burst, and the just lacquer everything?
And for the pick guard, what can i use to paint on plastic?
The body will probably be re-finished white (whit matching headstock) and the pickguard black)
thanks for the answers :)
https://linustechtips.com/topic/219408-modding-a-squier-p-bass/
I don't think spray painting it is the best choice, unless you are using a air brush with car paint.
try http://reranch.com/products.htm http://www.manchesterguitartech.co.uk/nitrocellulose-lacquer/ or Clou Waterbeits
if you google see through blonde paint guitars someone in a forum wrote:
If you just want a tint, but have it translucent, you can mix aniline dye, reduced in lacquer thinner, with clear lacquer to achieve a see-through color.
https://linustechtips.com/topic/219408-modding-a-squier-p-bass/#findComment-3008026
Don't use spray paint, it will suffocate the wood and you'll run into a lot of issues.
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/219408-modding-a-squier-p-bass/#findComment-3008363
I personally own a Gibson Thunderbird and a Fender Jazz Bass Japan (which looks like this one)
-snip-
Yeah, i wanted to go for that look, hoping that the wood grain will be kinda nice ^^
i guees i have to use wood-related paint (i don't know the term in english, but kinda like the one used for furniture? for the same look of the bass above)
https://linustechtips.com/topic/219408-modding-a-squier-p-bass/#findComment-3008420
You wont get one that looks like that, cause I dont think you have the right wood
yes i now, i'll probably have low-grade maple, but since the paint cracked in some spots (my bad) you can see the grain. Even if it's not that amazing i'm ok with it :)
https://linustechtips.com/topic/219408-modding-a-squier-p-bass/#findComment-3008465
ya i believe they use basswood in the p bass so its light in colour, any ways probably use a super light coat of blonde paint mixed in with paint thinner, let it dry, and clear coat it, there is a eHow link which teaches basics.
https://linustechtips.com/topic/219408-modding-a-squier-p-bass/#findComment-3008495
