Hi guys,
I have a new system unit and as for the first week, when I turn it on it powers up then after 1 second it losses power but then it reboots itself and it will push through. This happens everytime I start up the PC. Is this normal?
CPU: Core i7-4790k Motherboard: Asus Maximus VII Hero Ram: Crucial Ballistix Sport 1600 CAS 9 16GB SSD: Samsung 840 EVO 120GB SSD HDD: 2TB Seagate Barracuda
GPU: Asus gtx770 2gb ddr5 direct cu11 oc PSU: Seasonic X750 80+ GOLD Full Modular Case: CM 690 III Cooling: Noctua NH-D14
OS: WINDOWS 8.1 64BIT SL
Others: Corsair SP fans X5, NZXT fan controller, NZXT Sleeves
https://linustechtips.com/topic/219007-pc-power-up-fail/
Hi guys,
Have you tried the methods in this thread?
http://linustechtips.com/main/topic/42440-readme-how-to-respond-to-a-no-post-or-no-power-up-situation/
The most common result of insufficient wattage is a paperweight that looks like a PC
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3002820
not yet. Thanks for pointing me to this.
Is the cooler on your CPU seated properly?
I'll re-seat it later thanks.
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3002853
Hi guys,
I've done the recommendations above and I have also tried a different power cable but its still the same. The usual one failure power up.
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3018829
Hi guys,
Do you have another PSU to test with?
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3018926
have you tried to OC?, could be a failed OC then it restarts to set defaults then boots ?
Specs
CPU-Intel I7 4790K- @ 4.5Ghz / Mobo - Asus Maximus Hero VII / GPU - GTX 980 @ 1592MHz / RAM - 16Gb Corsair Vengeance Pro @ 2400Mhz / Cooler - Corsair H105 / SSD - Samsung 250gb 840 EVO / HDD - 2x 2tb Seagate/3x 3tb Seagate / PSU - Corsair RM1000 / Keyboard - Corsair K70 / Mouse - Corsair M65 / Case - Custom Glass panel Corsair Obsidian 750D -  Still saving for upgrades =)
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3018953
All parts are brand new and tested before being shipped.
Hmmm.. maybe that's the culprit. I did change some settings in bios. Maybe I'll set it to default first and test?
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3019803
yup give that a try, best best is to move the jumper, on the MB or pull out the MB battery for a couple of minutes , best of luck buddy
Specs
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3019905
Yep, BIOS reset should do the trick. Chances are its unhappy about a setting, whatever it is, and so it does a bit of a jump to start up with the default settings. Make sure your boot order is also correct.
Project Tomahawk:
CPU: Intel Core i7 4790k
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
PSU: Seasonic M12II EVO 620W
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3020907
Maybe something went wrong while shipping? Have you thought about contacting the company that sold you the stuff?
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3022384
I've already reset the bios to default settings but still no luck. I'll reseat the battery and check boot order.
I'll check with the company.
I've checked with the company and he said he also experienced this with higher end mobos. One other client he had with 2 titans but with a different mobo also have this problem. Do you guys think this is normal? Any harmful effects?
Here's the video. http://youtu.be/r8jZ_yZ1ClI
Edited by frostentangle
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3023383
So wait, your PC is working?
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3025614
Sorry if I wasn't clear enough. Yes it's working but it always do that thing on the video above. About 0-4 seconds it tries to boot up but 'fails' and restarts again but after that everything is fine.
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3026226
I have the same mobo and it doing the same thing, when i build my pc and booted it for the first time it did the same thing like the video above, but now its ok, it might be mobo problem try to boot your pc from the "start" buttom on the mobo one time
I will try that.
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3026785
I just tried it and it did the same thing while using the "start" button. Could it be that this is a bad batch of mobo?
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3034042
If I remove the battery will it reset BIOS settings and version?
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3095621
Just the settings not the version
Specs
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3097691
i noticed something else,do you close your PSU? by close i mean from the button behind of the tower
Yes. But even if I do leave the PSU 'open' and boot from cold boot it still does this fail boot once.
I updated my bios and it has improved a bit, meaning it still has the fail boot but it is now less noticeable than before.
https://linustechtips.com/topic/219007-pc-power-up-fail/#findComment-3129614
