i7-5820K cooler
Go to solution Solved by Toddwjp,
yep
It's a 2011-3, you can check on the cooler specs if you wan't to.
https://linustechtips.com/topic/218850-i7-5820k-cooler/#findComment-3000808
What cooler do you have now
https://linustechtips.com/topic/218850-i7-5820k-cooler/#findComment-3000814
