System upgrade
Go to solution Solved by Arunkrishna,
4130 is good to go, I tend not to recommend AMD CPUs these days because Intels performance advantage is too big :P
Alright :) . And what about motherboard ?? Is Biostar HiFi B85S3+ good choice ?? I've chosen it coz,  it  got better audio amplifier .
what do you think??
Hello Everyone  :)
                              I have planned to upgrade my vintage system :P , so i need your suggestions!!!!
My current system specs:
                                          CPU: Intel Pentium D 820( Antique one :P )
                                          MB:   Asus P5GZ-MX
                                         RAM: 2x1GB DDR2
                                         GPU: On board.
                                         HDD: Seagate Barracuda 1 TB
                                        SMPS: Corsair  VS450(450W)
           As you can see, i'm using vintage system emotion-5.gif , So i have planned to upgrade Motherboard , CPU & of course RAMemotion-2.gif. My budget is ₹15000(~$250 or max $300), As i'm tight in budget., i have made choice of  i3-4130 . Its single core performance is very good compared to fx6300. And also i3 got very less TDP of 54W compared to 95W of fx6300. Even i thought of new A10-7800, unfortunately i haven't found in local market yet(i live in india).
For motherboard i've selected B85 chipset (MSI B85M-G43 ,Gigabyte GA-B85-D3H or Biostar HiFi B85S3+).
I am decent gamer (Burn out, GTA4 blah blah.. ), and i will watch hd videos..
 Is this good choice?? and plz do suggest me a good entry level GPU ,. if it's fits into my budget.
Thank you :D
https://linustechtips.com/topic/218680-system-upgrade/
i3 4130 is a good choice. How much is a R7 260x in your area? Or maybe drop to a 250X to keep in budget.
https://linustechtips.com/topic/218680-system-upgrade/#findComment-2998885
Thanks for the rply.
                 r7 260x cost aprx $165(10000) and 250x aprx $107(₹6500).
Hmm. You could grab the i3 4130 now with the board and the RAM then upgrade to a dedicated GPU later :)
Either way you're in for 1 hell of an upgrade :)
https://linustechtips.com/topic/218680-system-upgrade/#findComment-2998918
Ha ha ha ha yeah.. My bad . I have to drop gpu for now!!! But i3 4130 is good to go rite???  or any amd based similar cpu or apu will i get??
https://linustechtips.com/topic/218680-system-upgrade/#findComment-2998942
https://linustechtips.com/topic/218680-system-upgrade/#findComment-2998952
what do you think??
https://linustechtips.com/topic/218680-system-upgrade/#findComment-2998973
what do you think??
Not used the board myself but it looks fine :)
https://linustechtips.com/topic/218680-system-upgrade/#findComment-2999018
Hello Everyone  :)
                                          MB:   Asus P5GZ-MX
                                         RAM: 2x1GB DDR2
                                         GPU: On board.
Thank you :D
Where r u going to buy form.
https://linustechtips.com/topic/218680-system-upgrade/#findComment-2999664
