IO and Expansion Slot Dimensions
Solved by carolkarine,
I've been doing a lot of research.
ultimately the cut-out can vary so long as it allows for the bracket to mount. in such a case, refer to the PCIe specifications. I've attached them to my reply. refer to pages 75 and 76
EDIT: attached the file.
Featured Topics
JFRStudent ·
Posted in Photography and Videography1 -
4
4
amir2927 ·
Posted in CPUs, Motherboards, and Memory4 -
realfireguy ·
Posted in Graphics Cards0
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
