So I probably just fell in love with the GTX 980 and once again I find myself at this dilemma.
The machine I'm building will be hooked up to a 1080p HDTV. So it will be stuck at 1920x1080 at 60Hz. (building the family Steambox)
I want something power efficient and able to run anything at the best settings (and enhancements for older games and emulation).
But I fear that something as powerful as the 980, or even the 780Ti, would just have too much of the GPU going to waste.
I'd love to hear some thoughts on this scenario.
I'm left wondering if a GTX 780 might be the most suitable option given this setup.
https://linustechtips.com/topic/218171-gpu-for-hdtv-how-much-is-overkill/
I'd disagree. 780Ti isnt really overkill for 1080p gaming, considering that games are now only gonna get more demanding, regardless of resolution. But the 900 series does have a cool feature that puts the unused cores to work and power managment featres that boosts other components when parts of the gpu is idle.
How many computer programmers does it take to change a light bulb?
None, that's a hardware problem.  :D
780 might be a little over kill, but then again, I play on 720p with my 780 :P
I'd say a 760/770 would be good, if you want a 970/960.
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
Get a 970, or 780
970 is not 1080p at all... it's beyond it since it has 4gb vram and it's meant to be used for higher resolutions.
I'd say 270x, 285, 280x
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
I would go with a GTX 770 honestly
When the latest generation comes out, it will be super expensive, whereas the 770 will not be, you will be able to get a 770 for a significant discount.
The 770 is perfect for 1080p anyways at the moment.
Compatible with Windows 95
Their is no such thing as overkill.
The better the GPU the longer it will last you while it might seem overkill for 1080p right now it won't be in 2-3 years.
RTX2070OC
