I hate to burst your bubble but 140mm case fans aren't that cheap, your gonna have to pay more money for a decent 140mm fan
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/217994-case-fans/#findComment-2989728
can u recommend one for under 10 dollars.
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/217994-case-fans/#findComment-2989810
What kind of dollars are you using and what are you using the fan for?
https://linustechtips.com/topic/217994-case-fans/#findComment-2989832
well dollars is us currency... so USD and it is a case fan, ill need 2 for the front intake and then there are 2 top mounts a sid mount a bottom mount and a rear exhaust, how many do u think i need.  no overclocking
https://linustechtips.com/topic/217994-case-fans/#findComment-2989840
There are Canadian dollars, New Zealand dollars, etc.
What are the specs of the system?
https://linustechtips.com/topic/217994-case-fans/#findComment-2989888
oh i didn't know that, excuse my ignorance.
i have my specs on my profile, but its a i5 4570 stock cooler, r9 280x (possible upgrade later to crossfire or a gtx 980 IT WAS ANNOUNCED LIKE 3-4 HOURS AGO SO EXCITING), fractal design define r4, msi b85-g41 (POSSIBLE UPGRADE TO a msi gaming 5 mobo), 1 kingston 120gb ssd, 1 seagate barracuda 1tb HDD, thermaltake t7 700w psu.
https://linustechtips.com/topic/217994-case-fans/#findComment-2989904
something like that
https://linustechtips.com/topic/217994-case-fans/#findComment-2989905
Are your current temps too high?
https://linustechtips.com/topic/217994-case-fans/#findComment-2989919
no they are fine
I don't have the define r4 yet its in the mail, i just thought that with the extra spac i would need some more positive airflow
https://linustechtips.com/topic/217994-case-fans/#findComment-2989934
no they are fine
I'd suggest waiting to see how the stock cooling does before preemptively buying new fans.
https://linustechtips.com/topic/217994-case-fans/#findComment-2989937
ok thanks, on an unrelated note, if i wanted to play bf4 at 1600x900 on an r7 265, could i get 60 fps on low settings
https://linustechtips.com/topic/217994-case-fans/#findComment-2989943
You should be able to get an average of ~60 fps at high settings.
https://linustechtips.com/topic/217994-case-fans/#findComment-2989953
Hello,
I am looking for a case fan that is 140mm, at least 60 CFM, maybe a little less, and at max, including shipping, 5 dollars.
I gotta say, it seems like you have a pretty nice system so i cant wrap my mind around why you need to buy cheap fans. If you really need fans you can but a 4-pack 120mm for about $15 USD
https://linustechtips.com/topic/217994-case-fans/#findComment-2996956
