Anyone knows something about this chip? Do you think Nvidia would make another shield tablet or start replacing the current chips with it?
Intel Core i9-9900K | Asrock Phantom Gaming miniITX Z390 | 32GB GSkill Trident Z DDR4@3600MHz C17 | EVGA RTX 3090 FTW3 Watercooled | Samsung 970 EVO 1TB M.2 SSD | Crucial MX500 2TB SSD | Seasonic Focus Plus Gold 1000W | anidees AI Crystal Cube White V2 | Corsair M95 | Corsair K50 | Beyerdynamic DT770 Pros 250Ohm
https://linustechtips.com/topic/217601-tegra-k1-64-bit/
At the moment they're sticking with the 32-bit Tegra K1 on the Shield Tablet. The 64-bit chip is only planned to go into chromebooks for now.
CPU: AMD FX-6300 4GHz @ 1.3 volts | CPU Cooler: Cooler Master Hyper 212 EVO | RAM: 8GB DDR3
Motherboard: Gigabyte 970A-DS3P | GPU: EVGA GTX 960 SSC | SSD: 250GB Samsung 850 EVO
HDD: 1TB WD Caviar Green | Case: Fractal Design Core 2500 | OS: Windows 10 Home
https://linustechtips.com/topic/217601-tegra-k1-64-bit/#findComment-2986642
