Upgrading Case from a NZXT Phantom 410 for silence?
Solved by aduman,
Thanks for the tip. My fans may not be the absolute best for silence alone, but from what I know they are not that bad, especially the noctua on the radiator. And since that doesn't help, I personally doubt any other fan would help. Or am I completely mistaken?
So, which high airflow but decently silent chassis would you guys recommend?
There aren't many options but here's what I'd do: I'd pick a case like enthoo pro or luxe and install high quality fans on them, like the ones I mentioned. Enthoo Pro is really good for this since you already get a great case for the money and this gives you the option to spend some money on fans.
