Gaming headphone/headset help
I need a new headphone/headset because my old Corsair 2000 wireless broke on me.
So I looked and I've narrowed it down to the
Steel Series Siberia Elite
Logitech g430
Or the Sennheiser Hd 598
Im open to suggestion. This'll mostly be for gaming and I prefer closed back.
cpu:i5-4670k | Ram: 16gb | Case:Nzxt phantom 520 | Psu: corsair tx850 gold
mobo: Asus hero | Gpu: evga 780 | Storage: seagate 2tb/smamsung evo 240gb
Sound: Corsair 2100 / Mouse: Corsair m65 mouse / Keyboard: Corsair k70 / Display Vizio 23inch hdtv (changing soon)
https://linustechtips.com/topic/217221-gaming-headphoneheadset-help/
Go with Sennheiser then add a modmic later. :D
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
I never used Sennhesier or anything along the lines with adding a modmic... I have used few of the gaming headsets, I would recommend the Steel Series Siberia Elites, linus said they sound ''ok'' (for gaming headphones that he hates, this is good) and if you want to go higher.... go with the SteelSeries Wireless H.. since you had wireless before? I bet you got used to listening to music while using the b room.
The time you enjoy wasting, is not wasted time.
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
