I am going to get a second 7970 card. My question is, would my current PSU be good enough, or will I need to upgrade that as well?
Here is my pc I built last summer:
Intel Core i7-2600K 3.4GHz Quad-Core Processor - not OC
Thermaltake Water 2.0 Performer 81.3 CFM Liquid CPU Cooler
Asus P8Z77-V PRO ATX LGA1155 Motherboard
Corsair Vengeance 16GB (4 x 4GB) DDR3-2133 Memory
Samsung Spinpoint M8 500GB 5400RPM Internal Hard Drive
Seagate Momentus XT 750GB 7200RPM Internal Hard Drive
Diamond Radeon HD 7970 3GB Video Card
Antec Eleven Hundred ATX Full Tower Case
Cooler Master Silent Pro Gold 800W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply
Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
I have looked at several PSU calculators and here are a couple of results I got if I had a second 7970 added to above build list:
pcpartpicker: 733W
newegg: 934w
outervision: 634w
asus: 1100w
what is interesting about the outervision site is that when I check for one card, it is rated at about 250w, but when I add the second card it rates it at 411w ... so this suggests that the second card is never going to use full power in a crossfire mode?
So the question remains, what is a good psu to use when I get a second 7970? Or would my current psu be good enough? I thought for sure that outervision was a good site, but after seeing this I am not so sure.
Rock On!
https://linustechtips.com/topic/2172-psu-help/
If you are really worried then you should run your PC at full load while measuring at the wall how many watts your PC is drawing from the wall.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/2172-psu-help/#findComment-29512
You'll be fine. The "recommended" wattage for a PSU is usually far higher than what the system actually draws, because PSUs are most efficient around 50-60% load. With dual 7970's your system will probably be drawing 500-600W.
https://linustechtips.com/topic/2172-psu-help/#findComment-29521
outervision is not verry accurate.. you should better sum up all TDP's of the produtcs to get some idea of its max power consumption
Since your PSU is 80+ Gold I think this shouldn't make any problems..
My Calc :
2*8Pin = max 300Watts
2GPUS á 2x8pin = max 600Watts
CPU :
Max TDP 95W (says the intel website) lets say u oc it till it draws.. 125Watts
Total of 725Watts for now which can be drawn in an ABSOLUTE 100% Peak load
Both HDD'S
Total of about 15Watts
with those we are at about 740Watts in 100% Peak load where EVERY component is drawing as much power as it CAN
Your DVD drive about 5 watts (again if you could load it up to 100%)
we're at 745Watts now.. (PS: im taking EVERY Watt value from the manufacturer's homepages and adding additional ~3% to simulate a total peak load of the component)
you should be pretty fine with some ~900Watt PSU with good efficiency.. Your's got about 91% at 100% load which means it is able to output about 728Watts..
You could stick with your current PSU, if you think you will never push everything above its limits (and again this is roughly calculated.. I've added more to my calculations like GPU's both would never get about 600Watts.. because you could not load both at 100% while everything else is at 100% too..(well by benchmarking like crazy it would be possible) because : better more then less..
If your PSU isn't good enoguh for the setup it wont break anything cuz it would turn the whole system down.. safty first and then you could even go and buy a new one instead of throwing this money out now when you do not know if you ever need a greater PSU.
Long story short:
Stick with your current one it should fit properly if you dont do hardcorebenchmarking and Overclockings and even if it's not enought: go and buy a new one :) it wont destroy anything in your build
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
https://linustechtips.com/topic/2172-psu-help/#findComment-29522
My Calc :
CPU :
Both HDD'S
Long story short:
Thanks, that has been very helpful. I will now gladly go get my second card once the wife loosens her kung-fu grip on our cash, haha
Rock On!
https://linustechtips.com/topic/2172-psu-help/#findComment-29586
My Calc :
CPU :
Both HDD'S
Long story short:
haha :D
10charr
https://linustechtips.com/topic/2172-psu-help/#findComment-29602
