900d front radiator question
Solved by Monty007,
Ahhh thanks for this do you have any links to the builds? I am okay with cutting out the bottom of the 5.25 with the cutting tool on my Dremel but I am using a fan controller in the middle slot, could I maybe still do this?
I'll have to look through my old research posts. Lots of stuff on OCN but I don't have them bookmarked anymore since I completed the build. If I find them I'll post back here.
You can still do it. Just cut out the bottom slot. Should give you all the room you need. Are you going to run the fans in a push or pull setup on the front rad?
