Will this cooler fit?
Go to solution Solved by Zeke,
How do they side panels on the 350D go on? Is it a slide on type of thing or is it on a hinge?
She wouldn't mind drilling some holes into the side panel in order to make it work
Slide on.
Although Bitfenix Comrade also has a listed cooler clearance of 160mm...
My friend has a Be Quiet! Shadow rock 2 cooler on a AMD mobo
Im thinking of getting her a Corsair 350D, I was wondering if it would fit.
Currently she has a Bitfenix Comrade, the cooler barely fits. with about a millimeter of clearance between the side panel and heatsink
https://linustechtips.com/topic/216839-will-this-cooler-fit/
350D has a CPU cooler clearance of 160mm. Shadow Rock 2 is... 160mm. So the answer is "no" (who knows how they calculate the maximum height) or "barely".
EDIT: Oh wait, it's 160 mm "without mounting material). Probably will not fit.
Any unknown button should be pressed even number of times.
https://linustechtips.com/topic/216839-will-this-cooler-fit/#findComment-2972410
https://linustechtips.com/topic/216839-will-this-cooler-fit/#findComment-2972424
Slide on.
https://linustechtips.com/topic/216839-will-this-cooler-fit/#findComment-2972429
Zeke, on 17 Sept 2014 - 02:49 AM, said:
Slide on.
Hmm. Alright, that about answers it.
Thanks man!
https://linustechtips.com/topic/216839-will-this-cooler-fit/#findComment-2972464
They are marketing max 160mm? Lol nice one corsair, try to sell AIOs :D
It will fit
Sauce: http://linustechtips.com/main/topic/41726-small-but-powerfull/
Hrm, I gotta ask that guy how much space is there between the cooler and the panel.
https://linustechtips.com/topic/216839-will-this-cooler-fit/#findComment-2972833
