Old Boot drive problems
Go to solution Solved by Taipeek,
Just delete the boot.ini file.... win 7 is no longer using this file for boot....
Be careful playing with XP and 7, once I managed to instal XP on my other drive when my primary drive with 7 was connected and it messed up my 7s and I had to reinstal it.
I've noticed that when I'm doing work on my pc and I have the current boot SSD disconnected, the system tries to boot off the HDD thats in there and brings up an old Windows XP bootloader. I used to have multiple copies of Windows xp on that HDD (have since removed them all, mostly i see) but the boot.ini file still exists. How do I completely remove this safely without corrupting things like MBRs or my current Windows 7?
I am whatever I am.
https://linustechtips.com/topic/21675-old-boot-drive-problems/
https://linustechtips.com/topic/21675-old-boot-drive-problems/#findComment-265994
