http://pcpartpicker.com/user/TehCaucasianAsian/saved/xXXnTW
This is my current build, and I have my FX-6300 overclocked to 4.6GHz. According to CoreTemp, my temperatures even when running Prime95 never go above 47C, which I find hard to believe since I'm running a 1.1GHz OC and only using a $30 air cooler with a single fan inside of a terribly cooled case. I have the voltage bumped up to over 1.4 by a little bit, so I figured temps would go up more than they did. I feel like the temps should be higher and whatever is reading temperatures is broken and I am potentially putting my CPU at risk... any suggestions?
https://linustechtips.com/topic/216678-is-my-cpu-running-safely/
It should be just fine, though with a lot of AMD CPUs the temperature sensors are not working properly.
https://linustechtips.com/topic/216678-is-my-cpu-running-safely/#findComment-2969939
Did you try to look at your BIOS temp readings? What are your ambient temp?
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/216678-is-my-cpu-running-safely/#findComment-2969994
Use HWmonitor and look at the motherboard socket temp. Your CPU temp sensor is probably faulty.
https://linustechtips.com/topic/216678-is-my-cpu-running-safely/#findComment-2970060
