I am new to water cooling an wanted to know what pumps are good to use. I am looking for quiet operation and it will have to fit in an Arc Midi R2 with a res attached. Also, any res suggestions would be greatly appreciated. I will be cooling a Haswell i5 and a 7850 with 60mm 240 rad and a 45mm 240 rad. Thank you in advance for your suggestions.
https://linustechtips.com/topic/21610-how-do-i-choose-a-pump/
Linus recommends the Swiftech mcp655, so I'd go with that.
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/21610-how-do-i-choose-a-pump/#findComment-263965
There is no reason at all to specifically recommend the MCP655. There is nothing special about it.
What I would recommend is a Laing Pump. The MCP655 is in fact in the "family" of Laing pumps but nothing more than that. Laing pumps come in two "flavors". The D5 and the DDC. The D5 is more expensive, bigger, quieter, runs cooler and is slightly better.
Laing pumps have an MTBF of 50,000 hours. Something around 6 years of running non-stop.
If you go to a water-cooling site there will most likely be a Laing pump sub-section. From all you need to know is; they are all the same pump that is just re-badged and some pumps have more "features" such as a tacho/rpm wire. You obviously pay for the features.
Otherwise; like I said they are all the same thing with a different sticker.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/21610-how-do-i-choose-a-pump/#findComment-264071
Do i need to buy an aftermarket pump top for a D5 or is the stock one okay?
The stock one only has 1/2" barbs. If you get a pump top you will have threads that you can screw your own fittings into. It will also perform slightly better.
But you don't have to if you are fine with the standard top.
https://linustechtips.com/topic/21610-how-do-i-choose-a-pump/#findComment-264428
