I recently bought a razer adaro stereos cause my brother said they will sound good cause he likes his kraken pro which gives a nice bass. the sound is not that bad. but im not good enough to tell the difference. i just want a better sound if i can get them. i was thinking of selling them and getting hyperx cloud. do you guys have any suggestions? the clouds are sold in my place for $100 and the ath-m50 for $130. should i keep my razer adaro or sell them and get a different headphones. other suggestions are welcome. Thanks.
https://linustechtips.com/topic/215850-help/
"not good enough to tell the difference" uhm... what?
Try them out first (if possible), if you truly don't notice a difference, why spend the money, and the hassle for an upgrade that means naught.
Personally, the Hx Clouds are still gaming headsets, they can be outdone by some audiophiles and a modmic or desk/stand mic, granted it will run you some more pretty pennies.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/215850-help/#findComment-2956571
Sound is really subjective... The Cloud is not bad if you need a headset. You could look at the ATH-M30X.
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/215850-help/#findComment-2956581
That depends on what you get from selling them.
FYI i lol'd with the title
:D
maybe ill get $80 from the $100.
not good enough to tell the difference cause im not audiophile. :D if im going to buy the hyperx. i wouldnt be able to try them before i can buy them. thats how stores here works :( but i theres a store for audiophiles that i can try headphones. i can get the m50 there for $134 usd or akg k619. i like bass btw. https://www.facebook.com/eggheadph. that is the link for the store. Thanks :)
https://linustechtips.com/topic/215850-help/#findComment-2956892
:D
You don't need to be an audiophile to distinguish what's bad, good, or better, that's all subjective.
I will always recommend that you buy a headset that has a more flat soundstage, then adjust the highs, mids, and lows with an equalizer, you'll always get better results than a headset that's tuned for bass.
What I always recommend on topics like these (in reproduction from my first post here on the LTT forums and personal experience) is that you look at the Beyerdynamic DT 770 Pro's. I have zero complaints with them. You'll need a modmic (http://www.modmic.com/) or a desk mic such as the AT2020, or Blue Snowball (two recommendations, of many available) if a mic is necessary, however.
https://linustechtips.com/topic/215850-help/#findComment-2956965
ill try to look for dt770. but hope it doesnt exceed $130. the store i linked you doesnt sell (or it isnt posted yet) those. any other suggestions?
https://linustechtips.com/topic/215850-help/#findComment-2957221
Their banner has Beyerdynamic listed, so at some point, one can assume that they had/have Beyerdynamic products. You could give the store a call, and find out for certain.
I have no other suggestions from personal experience, however Sennheiser and AudioTechnica are both well regarded. It's likely that a quality setup form any of these three companies will run you more than $130, especially when the necessity for an external mic comes into play.
https://linustechtips.com/topic/215850-help/#findComment-2957245
ill call their store tomorrow. its night time here. :) can you please look at their online store for anything you can recommend for under below P6,000 (converts to $140 usd) if youre not busy. :D much appreciated.
https://linustechtips.com/topic/215850-help/#findComment-2957326
