PS3 overheating?
By
Shaqo_Wyn
in Console Gaming
in Console Gaming
Solved by Bogica,
Hey mate. It's completely normal for it to overheat after so many years. Open up the case and clean it out, check if the fan is still running and replace the thermal paste, the ones you said you are going to use are much better than the stock ones so the system will run much cooler. Hope this helps! ![]()
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
