Will 860w Corsair PSU do for this system?
Build:
Corsair 780t
i7 5930K
16GB DDR4 RAM 2800Mhz
2x 780 Ti
1TB Seagate Barracuda
3TB Seagate Barracuda
Corsair GS 128GB SSD
Samsung 256 Evo Pro SSD
6* SP120 Fans
3* AF 140 fans
Water Cooling:
EK D5 Vario X-TOP
EK Supremacy Evo CSQ
2* EK 780 Ti Backplate
EK X3 250 Res
2* EK 780 Ti Water Blocks
Alphacool 360mm RAD
PrimoChill 3/8" Tubing
14 PrimoChill Revolver Fittings
Will 860w PSU be enough? I know many don't require power. I just copy pasted it from somewhere else. The reason i am asking is because i already have a Axi 860w lying around and would really like to use it.
https://linustechtips.com/topic/215261-will-860w-be-enough/
Yes if you're not pushing the gpu's and cpu very hard with overclocking, if you do you're on the edge I think...
Build log "Whiplash" : http://linustechtips.com/main/topic/158477-the-hero/
Whiplash: 4790k@4,4Ghz|Maximus VII Hero|4x4Gb Red/Black HyperX fury 1866Mhz|R9 290 Tri-X|Modded 450D|Sleeved cables on a M12II evo 850W|M500 480Gb| BenQ XL2411T@144Hz
Laptop: 4700MQ|16Gb@1600Mhz|Quadro 1100M|1080P|128Gb SSD|500Gb 7200RPM hdd
https://linustechtips.com/topic/215261-will-860w-be-enough/#findComment-2947343
Build:
Corsair 780t
i7 5930K
2x 780 Ti
6* SP120 Fans
3* AF 140 fans
Water Cooling:
EK D5 Vario X-TOP
EK X3 250 Res
Alphacool 360mm RAD
Doesn't the Axi 860w come with a handy tool that lets you check it's power usage?
https://linustechtips.com/topic/215261-will-860w-be-enough/#findComment-2947392
Assuming you don't try to push everything out of both the CPU and GPU it should work. I however would prefer to get a higher wattage PSU, as it would make it more efficient.
CPU: Intel I7-4790k | MOBO: Asus Sabertooth Z97 Mark 1 | Ram: Corsair Vengance 32GB 1600hz | GPU: EVGA GTX980 Reference
PSU: Corsair EVGA G2 850W  | SSD: Intel 730 Series 480GB, Kingston SSDNow V300 120GB | HDD: WD Black 1TB
 CPU Cooler: Corsair H105 | Case: Corsair 760T (White) | Peripherals: (2)Asus VS247H-P, Corsair M65, Corsair K70 RGB w/ Brown Switches
https://linustechtips.com/topic/215261-will-860w-be-enough/#findComment-2947460
