Listen and help pls
http://youtu.be/G3c61yChUuw
is that you talking in the background or the speakers
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/214728-speaker-issue/#findComment-2938514
what speakers are they and are they new, old,
https://linustechtips.com/topic/214728-speaker-issue/#findComment-2938523
do you have a cable that you can swap out for there old one
https://linustechtips.com/topic/214728-speaker-issue/#findComment-2938574
iv swapped everything i can, cables, amps, thier is one attached from the back that can't be removed. though. their is also a tweeter speaker on the back.
is it possible to filter for the low/high freq is busted?
https://linustechtips.com/topic/214728-speaker-issue/#findComment-2938594
possible although not likely you should post this in the audio sub-forum as there are people there who have much more experience and you should get an answer to your problem
https://linustechtips.com/topic/214728-speaker-issue/#findComment-2938630
ok thx
welcome
https://linustechtips.com/topic/214728-speaker-issue/#findComment-2938666
It sounds like either you have a bad connection maybe try replacing the cable you are currently using, or a second more likely scenario is that the driver has been on a full volume setting for an extended period of time which could and normally with cheaper or even some of the more premium speakers could result in pernament driver damage so my suggestion would be to borrow and test the speakers on a lower volume with a different cable or maybe a different input device or if the driver is damaged I'm afraid you will simply have to invest in a new one, although some RMA and warrenty cases will cover issues like this so it might be worth investigating that option as well.
Hope this helps :3
https://linustechtips.com/topic/214728-speaker-issue/#findComment-2938729
