Steam help
Go to solution Solved by AlwaysFSX,
There's no sign out option in Steam menu
-snips-
Change user does it.
Hey all,
after reading this info I decided to uncheck the option in Steam which allows it to log in automatically (without asking your password) sign in, but problem is, I can't find such thing in Steam. How can I disable automatic sign in of Steam?
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/214609-steam-help/
Open Steam, click Steam in the top left, sign out, click button below password box, sign in.
https://linustechtips.com/topic/214609-steam-help/#findComment-2936601
You know you need to click twitch chat links to be affected right? That's like rule number 1 of twitch, trust no links that aren't from mods/streamer.
I know, but for more security, I wanna turn off automatic signing in
https://linustechtips.com/topic/214609-steam-help/#findComment-2936606
Thx for help.
https://linustechtips.com/topic/214609-steam-help/#findComment-2936648
It worked?
Yes :)
https://linustechtips.com/topic/214609-steam-help/#findComment-2936791
