I'm thinking about buying the new NZXT S340 case. The stock fans are the FN V2 fans, the same that is included with the H440. How are they? And how do they compare to Bitfenix Spectre Pros?
If you want to join a really cool Discord chatroom with some great guys here from LTT and outside this community then PM me!
https://linustechtips.com/topic/214559-fn-v2-fans/
120's are rated for 45CFM at 21dB, 140's 50 and 21 respectively, not amazing but sufficient for some builds.
Spectre Pros are better spec wise.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/214559-fn-v2-fans/#findComment-2938726
