Sooo, I am pretty sure i got everything down this time. But new build won't post. "hdmi no signal". I tried using vga cable, a different monitor. Nothing. IM pretty noob. im opretty sure i got everything down.
EDIT: g3258, h81-plus mitx, cx430psu
even BIOS update? :P
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/214465-bios-wont-post-help/#findComment-2934438
EDIT: g3258, h81-plus mitx, cx430psu, corsair 250d,
check again if all the cables are connected. do the fans start spinning?
https://linustechtips.com/topic/214465-bios-wont-post-help/#findComment-2934454
all fans spinning
Yep it's probably(probably(doesn't mean I'm totally right tho)) the BIOS. Find a haswell chip and use it 1st to boot up then download the latest BIOS. :) I don't know if your MOBO can update the BIOS through USB so finding a haswell chip(maybe borrow from a friend) then update it when it boots up is one way to fix it :D
https://linustechtips.com/topic/214465-bios-wont-post-help/#findComment-2934466
is it not haswell already?
https://linustechtips.com/topic/214465-bios-wont-post-help/#findComment-2934494
It's haswell refresh. They're different :)
https://linustechtips.com/topic/214465-bios-wont-post-help/#findComment-2934513
so i have to update bios??? what if i can't????
That... I don't know. There's some retailers that might provide BIOS update service. Buy an ASUS/ASRock H97 maybe? If you buy a new mobo it can also give benefits to you like overclocking(for some ASUS H97 mobos). If you just bought it recently, try to ask for a refund.... hopefully.
https://linustechtips.com/topic/214465-bios-wont-post-help/#findComment-2934548
Try switching ram stick positions or with one at a time . Try re-positioning the gpu or use the onboard one if you have one , also check if all cable are in place and if pci cards (if you have ) are placed correctly .
Also , you can't update the bios since you can't see anything . Do you use multiple graphics cards ?
        > I have approximate knowledge of many things <
https://linustechtips.com/topic/214465-bios-wont-post-help/#findComment-2934643
Try changing ram positions and pls check the sticky for no post and then post the results here .
THE LITTLE DEVIL : i5 4690k on NOCTUA NHD15
Asus z97 sabertooth mark 2
WD black 1TB & WD Green 2TB HDD, Samsung 840 Evo 240gb & Hyperx 240gb SSD
RAM- Corsair vengence 16gb and hyperx fury 8gb
PSU-Seasonic sII 620 wtt power supply
PErPHERaLS: Logitech g403 mouse, Redgear cherry MX brown switches, Logitech gamepad f310,Cosmic byte XXL RGB mousepad
Audio: SennheiserHD 558 and antlion mod mic
PHOnE: Realme 3 pro
https://linustechtips.com/topic/214465-bios-wont-post-help/#findComment-2934887
