I've been wanting to make a Pc for a while that's has great price/performance but I have to settle for a pc that is about $500 and yes the monitor is included in the budget it's a very extremely limited budget so what do I do?
By the way I am going for a IPS monitor because visuals.Also I want good 1080P performance with this budget so putting most games on high settings and expecting a frame-rate around 45-60FPS.
https://linustechtips.com/topic/214292-my-first-pc-help-me/
PCPartPicker part list: http://pcpartpicker.com/p/8dpm23
Price breakdown by merchant: http://pcpartpicker.com/p/8dpm23/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($54.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.66 @ Amazon)
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard  ($89.99 @ Newegg)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1866 Memory  ($81.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($56.98 @ OutletPC)
Video Card: Gigabyte Radeon R9 270 2GB WINDFORCE Video Card  ($151.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($79.99 @ NCIX US)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Newegg)
Total: $579.57
Generated by PCPartPicker 2014-09-12 20:49 EDT-0400
Sorry I forgot to mention I live in the USA Eastern area so prices are different and also I need it to be BELOW or slightly above $500 (the maximum limit above is $30) and I need an IPS monitor included
https://linustechtips.com/topic/214292-my-first-pc-help-me/#findComment-2931809
I really don't think you can get what you want for the budget you've provided.
I'd suggest saving up some more, mow some lawns, etc.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/214292-my-first-pc-help-me/#findComment-2931860
If you have a tv already that might make sense.
This is the best build I could do close to the $530 budget.
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($166.98 @ OutletPC)
Motherboard: ASRock FM2A88X Extreme4+ ATX FM2+ Motherboard  ($60.99 @ Newegg)
Memory: G.Skill Ripjaws Z Series 8GB (2 x 4GB) DDR3-2400 Memory  ($81.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($19.99 @ Newegg)
Monitor: Dell S2240M 60Hz 21.5" Monitor  ($114.99 @ Newegg)
Total: $560.57
If you want someone to see that you've replied you need to either Quote them using the link at the bottom right of the post, or tag them like this @ProJohnathan1
Otherwise they won't know.
https://linustechtips.com/topic/214292-my-first-pc-help-me/#findComment-2932009
Total: $560.57
Total: $560.57
I have a good tv that can go up to 60hz and 1080p if using hdmi but has no dvi ports or displayport.
https://linustechtips.com/topic/214292-my-first-pc-help-me/#findComment-2932077
The input lag will be slightly worse but you may as well use it. It'll save you $120. I have a friend who plays on his TV and he likes it just fine.
https://linustechtips.com/topic/214292-my-first-pc-help-me/#findComment-2932093
